Einleitung
Hey Leute, in dieser Anleitung werde ich euch zeigen, wie ihr das Gimbal, als auch das Gehäuse der DJI Mini 3 Pro Drohne austauschen könnt.
Nach einem Austausch des Gimbals oder der Kamera, muss die Drone möglicherweise kalibriert werden, allerdings kannst du das mit der DJI Fly App nicht machen, du benötigst dafür eine zusätzliche Software. In diesem Video wird erklärt, wie du das Gimbal kalibrieren kannst: https://youtu.be/mu03HWXplM4 (Englisch)
Was du brauchst
Videoanleitungen
Um dein Gerät wieder zusammenzubauen, folge den Schritten umgekehrter Reihenfolge.
5 weitere Personen haben diese Anleitung absolviert.
100%
Hier starten ›
9 Kommentare
Does anyone have a source for replacing the little rubber gimbal mounts?
Andre Purdy - Antwort
HI there! Does anyone know where I can buy the whole gimbal in USA? I remember seeing it somewhere but cannot find it
gbonilla - Antwort
Go to YouTube and check the link to the gimbal assembly in the description below the video
Arty -
mini 3 pro com port not show on device manegar any help.
Limon Khan - Antwort
Start trembling during flight after a horizontal stop. At the start, I can hear the gimbal noise from trembling (before taking off). I gently touch it, and it stops. I take off and fly a long distance.
If I stop it or it stops it by signal loss, the trembling starts again. if I never stop it and take gentle curves back, it may work. At abrupt stops, it starts trembling. I bring the drone back to me at 1-meter height. I gently touch the gimbal (without landing), and it stops. Then I fly again (if the battery is low, I land, change the battery, and start again, same steps, every time). I will probably buy a new one, so I can send this to repairs - did not check the guarantee yet.
- no problems during climbing up.
- only on horizontal movements and hard stops (release the lever on the controller).
I will try never to release the lever abruptly and never lose signal (a signal lost could be a hard brake, also)
??? Calibration can stop this strange error ????
Dorin - Antwort
