Zum Hauptinhalt wechseln
DJI Phantom 2 Vision+ Propellers Removal
Was du brauchst
  1. DJI Phantom 2 Vision+ Propellers Removal, Remove the battery: Schritt 1, Bild 1 von 3 DJI Phantom 2 Vision+ Propellers Removal, Remove the battery: Schritt 1, Bild 2 von 3 DJI Phantom 2 Vision+ Propellers Removal, Remove the battery: Schritt 1, Bild 3 von 3
    • Pinch the top and bottom tabs of the battery case, pull the battery straight out to remove it.
    • The metal connectors form a stiff mechanical connection with the battery, you will need quite a bit of force to remove the battery. Hold the Phantom Vision+ with one hand and remove the battery with the other.
  2. DJI Phantom 2 Vision+ Propellers Removal, Propellers: Schritt 2, Bild 1 von 1
    • Determine if the propellor is clockwise or counter-clockwise rotating.
    • Each arm is labeled with a rotation icon that shows the direction of propellor rotation.
    • If this icon is missing or you can't read it, you can determine the direction of rotation by examining the propellor.
    • A clockwise rotating propellor pushes air down while rotating clockwise, and the opposite is true for a counter-clockwise rotating propellor, and the propellor blade slopes up in the direction of rotation.
  3. DJI Phantom 2 Vision+ Propellers Removal, Removing clockwise rotating propellers: Schritt 3, Bild 1 von 3 DJI Phantom 2 Vision+ Propellers Removal, Removing clockwise rotating propellers: Schritt 3, Bild 2 von 3 DJI Phantom 2 Vision+ Propellers Removal, Removing clockwise rotating propellers: Schritt 3, Bild 3 von 3
    • Loosen a clockwise rotating propeller by holding the motor with one hand and spinning the propellor clockwise.
    • Remove the propellor.
  4. DJI Phantom 2 Vision+ Propellers Removal, Removing counter-clockwise rotating propellers: Schritt 4, Bild 1 von 3 DJI Phantom 2 Vision+ Propellers Removal, Removing counter-clockwise rotating propellers: Schritt 4, Bild 2 von 3 DJI Phantom 2 Vision+ Propellers Removal, Removing counter-clockwise rotating propellers: Schritt 4, Bild 3 von 3
    • Loosen a counter-clockwise rotating propeller by holding the motor with one hand and spinning the propellor counter-clockwise.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
David Hoyt
4.023 Reputation
43 Anleitungen geschrieben
Cal Poly, Team 25-89, Amido Spring 2010 Mitglied von Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 Mitglieder
63 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 7
Insgesamt: 7,077
