Einleitung
Use this guide to replace an Electronic Speed Controller (ESC) in your DJI Phantom Drone 2 Vision+. The ESC receives power from the central board, and a PWM control signal from the flight controller. There is one ESC for each motor, for a total of four. Removing an ESC requires soldering.
Note: the drone used in this guide probably looks different from yours! It's just a custom paint job, otherwise it's completely stock.
  1. Pinch the top and bottom tabs of the battery case, pull the battery straight out to remove it. The metal connectors form a stiff mechanical connection with the battery, you will need quite a bit of force to remove the battery. Hold the Phantom Vision+ with one hand and remove the battery with the other. The metal connectors form a stiff mechanical connection with the battery, you will need quite a bit of force to remove the battery. Hold the Phantom Vision+ with one hand and remove the battery with the other.
    • Pinch the top and bottom tabs of the battery case, pull the battery straight out to remove it.
    • The metal connectors form a stiff mechanical connection with the battery, you will need quite a bit of force to remove the battery. Hold the Phantom Vision+ with one hand and remove the battery with the other.
  2. Determine if the propellor is clockwise or counter-clockwise rotating.
    • Determine if the propellor is clockwise or counter-clockwise rotating.
    • Each arm is labeled with a rotation icon that shows the direction of propellor rotation.
    • If this icon is missing or you can't read it, you can determine the direction of rotation by examining the propellor.
    • A clockwise rotating propellor pushes air down while rotating clockwise, and the opposite is true for a counter-clockwise rotating propellor, and the propellor blade slopes up in the direction of rotation.
  3. Loosen a clockwise rotating propeller by holding the motor with one hand and spinning the propellor clockwise. Remove the propellor. Remove the propellor.
    • Loosen a clockwise rotating propeller by holding the motor with one hand and spinning the propellor clockwise.
    • Remove the propellor.
  4. Loosen a counter-clockwise rotating propeller by holding the motor with one hand and spinning the propellor counter-clockwise. Remove the propellor. Remove the propellor.
    • Loosen a counter-clockwise rotating propeller by holding the motor with one hand and spinning the propellor counter-clockwise.
  5. Remove the following screws from the underside of the Phantom: Twelve 2.0 mm hex bolts
    • Remove the following screws from the underside of the Phantom:
    • Twelve 2.0 mm hex bolts
    • Four Phillips #00 screws
  6. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  7. Gently lift up the top shell case. Do not attempt to fully remove the top shell. The GPS cable is still attached to the mainboard, avoid lifting the case too high or you may damage this connection.
    • Gently lift up the top shell case.
    • Do not attempt to fully remove the top shell. The GPS cable is still attached to the mainboard, avoid lifting the case too high or you may damage this connection.
  8. The GPS cable molex connector is located on the backside of the mainboard, near the battery opening. Pull the GPS connector straight up out of its socket. Lift the top shell case up and remove it from the body of the Phantom.
    • The GPS cable molex connector is located on the backside of the mainboard, near the battery opening.
    • Pull the GPS connector straight up out of its socket.
    • Lift the top shell case up and remove it from the body of the Phantom.
  9. Desolder all three motor wires. When replacing a motor, be sure to solder the new motor in following the same wire color order as when you removed it.
    • Desolder all three motor wires.
    • When replacing a motor, be sure to solder the new motor in following the same wire color order as when you removed it.
    • The motor spin direction is dependent on the order of the wires, and may not match this image exactly. If you forgot the order, check the arm directly opposite for reference.
  10. Remove the four 2mm hex motor bolts.
    • Remove the four 2mm hex motor bolts.
  11. Remove the motor from the motor mount. Remove the motor from the motor mount.
    • Remove the motor from the motor mount.
  12. Cut the zip-tie securing the signal and power cables. Unplug the ESC signal cable molex connector from the ESC. Unplug the ESC signal cable molex connector from the ESC.
    • Cut the zip-tie securing the signal and power cables.
    • Unplug the ESC signal cable molex connector from the ESC.
  13. Desolder the ESC ground and voltage wires from the mainboard. Be careful not to melt the plastic case bottom shell with your soldering iron or damage any electronic components.
    • Desolder the ESC ground and voltage wires from the mainboard.
    • Be careful not to melt the plastic case bottom shell with your soldering iron or damage any electronic components.
    • You can remove in-the-way cables by unplugging them and moving them aside. This will protect them from the warning above.
    • Be sure to plug these cables back in before reassembling your Phantom 2.
  14. Remove the two ESC securing screws. The clear plastic LED cover will either drop from the underside or need to be loosened with a plastic spudger. The clear plastic LED cover will either drop from the underside or need to be loosened with a plastic spudger.
    • Remove the two ESC securing screws.
    • The clear plastic LED cover will either drop from the underside or need to be loosened with a plastic spudger.
  15. With the ESC no longer secured to the airframe, lift it up and remove it. With the ESC no longer secured to the airframe, lift it up and remove it. With the ESC no longer secured to the airframe, lift it up and remove it.
    • With the ESC no longer secured to the airframe, lift it up and remove it.
Abschluss
7 weitere Nutzer haben diese Anleitung absolviert.
David Hoyt
3.667 Reputation
43 Anleitungen geschrieben
Cal Poly, Team 25-89, Amido Spring 2010 Mitglied von Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 Mitglieder
52 Anleitungen geschrieben
Is it a difference between ESC from different versions (1.0, 2.0 and 3.0) of Phantom 2?
jarbas_sjo - Antwort
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 38
Insgesamt: 5,076
