Einleitung
Use this guide to replace the back con board of a DJI Phantom 4 Advanced Remote Controller.
With step by step detailed instructions, you will be able to safely resolve issues that may arise with the back con board.
Was du brauchst
Remove the four screws with a Torx T8 screwdriver to access the back con board.
With tweezers, gently remove the large con board tab.
Use your hands to remove the two small clips. Pull out from the socket, in a horizontal direction.
Peel off the rubber grips to access the screw holes.
Remove the back board and set it aside.
Pull apart the back plastic panel.
Once the back panel is off, you will have access to the motherboard.
