Zum Hauptinhalt wechseln
DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement
Was du brauchst
  1. DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Remove the four screws with a Torx T8 screwdriver to access the back con board.
  2. DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: Schritt 2, Bild 1 von 2 DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: Schritt 2, Bild 2 von 2
    • Remove three screws using a Phillips #00 screwdriver.
  3. DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: Schritt 3, Bild 1 von 2 DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: Schritt 3, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • With tweezers, gently remove the large con board tab.
    • Use your hands to remove the two small clips. Pull out from the socket, in a horizontal direction.
  4. DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: Schritt 4, Bild 1 von 2 DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: Schritt 4, Bild 2 von 2
    • Peel off the rubber grips to access the screw holes.
    • Make sure to save your grips and do not to get them stuck to anything, you are going to want to save the adhesive.
    • Remove the back board and set it aside.
  5. DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: Schritt 5, Bild 1 von 2 DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: Schritt 5, Bild 2 von 2
    • Pull apart the back plastic panel.
    • Recommended tool for this would be the metal spudger, but not required.
    • Once the back panel is off, you will have access to the motherboard.
  6. DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement, Motherboard: Schritt 6, Bild 1 von 3 DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement, Motherboard: Schritt 6, Bild 2 von 3 DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement, Motherboard: Schritt 6, Bild 3 von 3
    • Disconnect ribbon tabs 1,2,5,8G, and 3.
    • Remove ribbon tab by pulling gently along motherboard. Do not pull straight out.
    • Then remove the plugs
  7. DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: Schritt 7, Bild 1 von 2 DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: Schritt 7, Bild 2 von 2
    • With the Phillips #00 screwdriver, remove the two Phillips screws.
  8. DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: Schritt 8, Bild 1 von 1
    • Double check to make sure all tabs, plugs and screws are removed or disconnected.
    • Gently lift motherboard out of the case.
  9. DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement, Control Sticks: Schritt 9, Bild 1 von 1
    • Remove the 10.7 mm Phillips screws using a Phillips #1 screwdriver.
  10. DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: Schritt 10, Bild 1 von 3 DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: Schritt 10, Bild 2 von 3 DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: Schritt 10, Bild 3 von 3
    • Gently remove the Gimbal Wheel control component from the body.
    • Take caution with the fragile wires when removing this component.
  11. DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: Schritt 11, Bild 1 von 2 DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: Schritt 11, Bild 2 von 2
    • Remove the 4 10.7 mm Phillips screws using a Phillips #1 screwdriver.
  12. DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: Schritt 12, Bild 1 von 2 DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: Schritt 12, Bild 2 von 2
    • Gently remove the Control Stick component.
    • Take caution with small and fragile wires to avoid breaking them.
  13. DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: Schritt 13, Bild 1 von 1
    • Repeat step 9 through 12 to remove the other Control Stick.
Abschluss
IUPUI, Team S1-G1, Harley Summer 2019 Mitglied von IUPUI, Team S1-G1, Harley Summer 2019
IUPUI-HARLEY-SU19S1G1
3 Mitglieder
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 11
Insgesamt: 1,015
