Einleitung
Use this guide to replace a broken propellor on your DJI Phantom. When replacing, be sure to match the original propellor spin direction.
Werkzeuge
Ersatzteile
  1. Press down on battery door release tab to flip the battery door open. Press down on battery door release tab to flip the battery door open. Press down on battery door release tab to flip the battery door open.
    • Press down on battery door release tab to flip the battery door open.
  2. Pull out the battery pack. Avoid pulling on the battery wires, excess stress may break the wires, damage the power connectors, or crack the internal solder joints. Avoid pulling on the battery wires, excess stress may break the wires, damage the power connectors, or crack the internal solder joints.
    • Pull out the battery pack.
    • Avoid pulling on the battery wires, excess stress may break the wires, damage the power connectors, or crack the internal solder joints.
  3. Pull the two halves of the XT60 power connector apart. It's a tight fit, so be careful not to hit your drone or yank on the cables when it releases!
    • Pull the two halves of the XT60 power connector apart.
      • It's a tight fit, so be careful not to hit your drone or yank on the cables when it releases!
  4. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  5. Silver-topped propeller collets unscrew counter-clockwise Black-topped propeller collets unscrew clockwise
    • Silver-topped propeller collets unscrew counter-clockwise
    • Black-topped propeller collets unscrew clockwise
  6. For propellors with silver collets: Use a 12 mm wrench or socket to loosen silver collets in the counter-clockwise direction. Once free, unscrew and remove the collet. Once free, unscrew and remove the collet.
    • For propellors with silver collets: Use a 12 mm wrench or socket to loosen silver collets in the counter-clockwise direction.
    • Once free, unscrew and remove the collet.
  7. For propellors with black collets: Use a 12 mm wrench or socket to loosen black collets in the clockwise direction. Once free, unscrew and remove the collet. Once free, unscrew and remove the collet.
    • For propellors with black collets: Use a 12 mm wrench or socket to loosen black collets in the clockwise direction.
  8. Gently press down the motor shaft and lift the propeller up to remove it. Gently press down the motor shaft and lift the propeller up to remove it. Gently press down the motor shaft and lift the propeller up to remove it.
    • Gently press down the motor shaft and lift the propeller up to remove it.
Abschluss
David Hoyt
3.667 Reputation
43 Anleitungen geschrieben
Cal Poly, Team 25-89, Amido Spring 2010 Mitglied von Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 Mitglieder
52 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 835
