Zum Hauptinhalt wechseln
DJI Spark Camera Replacement
Was du brauchst
  1. DJI Spark Camera Replacement, Propellers: Schritt 1, Bild 1 von 1
    • Push down on the propeller that is being replaced.
  2. DJI Spark Camera Replacement: Schritt 2, Bild 1 von 2 DJI Spark Camera Replacement: Schritt 2, Bild 2 von 2
    • Twist the propeller until it feels loose.
    • Pull on it until it comes off.
  3. DJI Spark Camera Replacement, Battery: Schritt 3, Bild 1 von 3 DJI Spark Camera Replacement, Battery: Schritt 3, Bild 2 von 3 DJI Spark Camera Replacement, Battery: Schritt 3, Bild 3 von 3
    • Flip the drone over.
    • Grip the left and right sides of the battery.
    • Slide firmly forward until it pops out.
  4. DJI Spark Camera Replacement, Lid: Schritt 4, Bild 1 von 3 DJI Spark Camera Replacement, Lid: Schritt 4, Bild 2 von 3 DJI Spark Camera Replacement, Lid: Schritt 4, Bild 3 von 3
    • Remove the four 1.5mm Hex screws.
    • Remove the two 1.5mm Hex screws near the camera head.
    • You may need to remove plastic nubs from the hex screws using a spudger first.
  5. DJI Spark Camera Replacement: Schritt 5, Bild 1 von 3 DJI Spark Camera Replacement: Schritt 5, Bild 2 von 3 DJI Spark Camera Replacement: Schritt 5, Bild 3 von 3
    • Hold the drone so the lid is facing up.
    • Insert the plastic opening tool into the side of the drone.
    • Slide the tool around the perimeter until you can lift the top off.
  6. DJI Spark Camera Replacement, Camera: Schritt 6, Bild 1 von 2 DJI Spark Camera Replacement, Camera: Schritt 6, Bild 2 von 2
    • Disconnect two gold antenna next to the internal GPS while removing the motherboard.
  7. DJI Spark Camera Replacement: Schritt 7, Bild 1 von 3 DJI Spark Camera Replacement: Schritt 7, Bild 2 von 3 DJI Spark Camera Replacement: Schritt 7, Bild 3 von 3
    • Remove all the Phillips #0 screws attaching the motherboard to the drone.
    • It is the piece with both the fan and GPS module on it.
  8. DJI Spark Camera Replacement: Schritt 8, Bild 1 von 2 DJI Spark Camera Replacement: Schritt 8, Bild 2 von 2
    • Remove the 3.0 mm Phillips #000 screw.
  9. DJI Spark Camera Replacement: Schritt 9, Bild 1 von 3 DJI Spark Camera Replacement: Schritt 9, Bild 2 von 3 DJI Spark Camera Replacement: Schritt 9, Bild 3 von 3
    • Remove the two Phillips #0 screws on the right and left sides.
    • Once removed, pull the front facing sensor out.
  10. DJI Spark Camera Replacement: Schritt 10, Bild 1 von 3 DJI Spark Camera Replacement: Schritt 10, Bild 2 von 3 DJI Spark Camera Replacement: Schritt 10, Bild 3 von 3
    • Gently remove the gimbal along with the camera from the top of the device.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Amelia Hagberg
415 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team S1-G7, Botvin Fall 2019 Mitglied von UMass Dartmouth, Team S1-G7, Botvin Fall 2019
UMASSD-BOTVIN-F19S1G7
3 Mitglieder
7 Anleitungen geschrieben
2 Kommentare
Good start, but missing many steps and details.
Basil Yokarinis - Antwort
I am now going to try and fix my drone. thank you so much
sebasnavarro1116 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 20
Letzte 30 Tage: 72
Insgesamt: 5,834
