Zum Hauptinhalt wechseln
DJI Spark Cooling Fan Replacement
Was du brauchst
  1. DJI Spark Cooling Fan Replacement, Propellers: Schritt 1, Bild 1 von 1
    • Push down on the propeller that is being replaced.
  2. DJI Spark Cooling Fan Replacement: Schritt 2, Bild 1 von 2 DJI Spark Cooling Fan Replacement: Schritt 2, Bild 2 von 2
    • Twist the propeller until it feels loose.
    • Pull on it until it comes off.
  3. DJI Spark Cooling Fan Replacement, Battery: Schritt 3, Bild 1 von 3 DJI Spark Cooling Fan Replacement, Battery: Schritt 3, Bild 2 von 3 DJI Spark Cooling Fan Replacement, Battery: Schritt 3, Bild 3 von 3
    • Flip the drone over.
    • Grip the left and right sides of the battery.
    • Slide firmly forward until it pops out.
  4. DJI Spark Cooling Fan Replacement, Lid: Schritt 4, Bild 1 von 3 DJI Spark Cooling Fan Replacement, Lid: Schritt 4, Bild 2 von 3 DJI Spark Cooling Fan Replacement, Lid: Schritt 4, Bild 3 von 3
    • Remove the four 1.5mm Hex screws.
    • Remove the two 1.5mm Hex screws near the camera head.
    • You may need to remove plastic nubs from the hex screws using a spudger first.
  5. DJI Spark Cooling Fan Replacement: Schritt 5, Bild 1 von 3 DJI Spark Cooling Fan Replacement: Schritt 5, Bild 2 von 3 DJI Spark Cooling Fan Replacement: Schritt 5, Bild 3 von 3
    • Hold the drone so the lid is facing up.
    • Insert the plastic opening tool into the side of the drone.
    • Slide the tool around the perimeter until you can lift the top off.
  6. DJI Spark Cooling Fan Replacement, Cooling Fan: Schritt 6, Bild 1 von 3 DJI Spark Cooling Fan Replacement, Cooling Fan: Schritt 6, Bild 2 von 3 DJI Spark Cooling Fan Replacement, Cooling Fan: Schritt 6, Bild 3 von 3
    • Remove the fan.
    • It is attached to the motherboard with several pieces of adhesive.
  7. DJI Spark Cooling Fan Replacement: Schritt 7, Bild 1 von 2 DJI Spark Cooling Fan Replacement: Schritt 7, Bild 2 von 2
    • Trace the fan wires to the side of the panel.
    • Unplug the wire from its connector.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Uzochi Anyanwu
408 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team S1-G7, Botvin Fall 2019 Mitglied von UMass Dartmouth, Team S1-G7, Botvin Fall 2019
UMASSD-BOTVIN-F19S1G7
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 16
Insgesamt: 1,346
