Zum Hauptinhalt wechseln
DJI Spark Internal GPS Replacement
Was du brauchst
  1. DJI Spark Internal GPS Replacement, Propellers: Schritt 1, Bild 1 von 1
    • Push down on the propeller that is being replaced.
  2. DJI Spark Internal GPS Replacement: Schritt 2, Bild 1 von 2 DJI Spark Internal GPS Replacement: Schritt 2, Bild 2 von 2
    • Twist the propeller until it feels loose.
    • Pull on it until it comes off.
  3. DJI Spark Internal GPS Replacement, Battery: Schritt 3, Bild 1 von 3 DJI Spark Internal GPS Replacement, Battery: Schritt 3, Bild 2 von 3 DJI Spark Internal GPS Replacement, Battery: Schritt 3, Bild 3 von 3
    • Flip the drone over.
    • Grip the left and right sides of the battery.
    • Slide firmly forward until it pops out.
  4. DJI Spark Internal GPS Replacement, Lid: Schritt 4, Bild 1 von 3 DJI Spark Internal GPS Replacement, Lid: Schritt 4, Bild 2 von 3 DJI Spark Internal GPS Replacement, Lid: Schritt 4, Bild 3 von 3
    • Remove the four 1.5mm Hex screws.
    • Remove the two 1.5mm Hex screws near the camera head.
    • You may need to remove plastic nubs from the hex screws using a spudger first.
  5. DJI Spark Internal GPS Replacement: Schritt 5, Bild 1 von 3 DJI Spark Internal GPS Replacement: Schritt 5, Bild 2 von 3 DJI Spark Internal GPS Replacement: Schritt 5, Bild 3 von 3
    • Hold the drone so the lid is facing up.
    • Insert the plastic opening tool into the side of the drone.
    • Slide the tool around the perimeter until you can lift the top off.
  6. DJI Spark Internal GPS Replacement, GPS: Schritt 6, Bild 1 von 2 DJI Spark Internal GPS Replacement, GPS: Schritt 6, Bild 2 von 2
    • Identify the GPS module on the motherboard.
    • The GPS module will be labeled as ‘DJI G116’.
  7. DJI Spark Internal GPS Replacement: Schritt 7, Bild 1 von 2 DJI Spark Internal GPS Replacement: Schritt 7, Bild 2 von 2
    • Remove the four 6.0 mm Phillips #000 screws holding the GPS module to the motherboard.
  8. DJI Spark Internal GPS Replacement: Schritt 8, Bild 1 von 2 DJI Spark Internal GPS Replacement: Schritt 8, Bild 2 von 2
    • Pick up the GPS module.
    • Carefully disconnect the GPS module ribbon cable from the motherboard.
    • Remove the GPS module.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Amelia Hagberg
415 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team S1-G7, Botvin Fall 2019 Mitglied von UMass Dartmouth, Team S1-G7, Botvin Fall 2019
UMASSD-BOTVIN-F19S1G7
3 Mitglieder
7 Anleitungen geschrieben
3 Kommentare
How About Spark's Wifi can't find?
Mark Ryan Fontelar - Antwort
GPS module ribbon cable is broken where can i buy?
manzoorsp67 - Antwort
please if some one have it send it to me
i will pay u
manzoorsp67 -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 39
Insgesamt: 1,964
