Einleitung
You will need to follow this guide step-by-step in order to separate the device into two piece. In doing so you will be able to replace the front panel, if damaged, as well as get to the other components inside of the device.
Was du brauchst
Using Blue Plastic opening tool pry the top rubber cover, then using the same tool remove the bottom panel
There are four prongs on the grill in the corners, closest to the power button switch. Use the plastic opening tool to release all four prongs from the panel, and then slide the plastic opening tool along the edge of the grill to allow it to easily slide off.
On the back panel (Opposite to the side containing the two speakers), Use the Philips head PH1 to remove all 7 screws (Screws: Head PH1 , Length 7cm).
2 weitere Personen haben diese Anleitung absolviert.
