Was du brauchst
Locate the four 3/32" screws on the bottom of your device.
Using a JIS #00 screwdriver, remove the four 3/32" screws.
After removing the screws, lift the cover off of the device.
Using a JIS #1 screwdriver, remove the six 3/32" screws that attach the base-plate to the speaker enclosure. These screws are marked with red circles.
Using a JIS #000 screwdriver, remove the two 1/16" screws from the areas marked with an orange circle.
2 weitere Personen haben diese Anleitung absolviert.
