Einleitung
If the DYMO LabelManager 160's keys are unresponsive, you may need to replace the keypad. This guide provides the replacement steps.
Was du brauchst
Remove the compartment cover to reveal the batteries. Remove the 6 old batteries.
To open the cartridge compartment, simply lift on the front of the device.
Using a Phillips #0 screwdriver, remove the four 1.3mm screws from the cartridge compartment and two 1.2mm screws from the battery compartment.
Using a spudger or other tool, lift and remove the front of the device. This should be done all around the device to ensure the two parts split correctly.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
3 Kommentare
Group 9: Over all looks great. Screwdriver at top of page should be under tools not parts.
In Step 4 the screws in the second picture 2x 1.2mm should be circled in orange and should be a separate bullet with appropriate coloring.
Possibly add a picture using the spudger, so the user knows exactly where they need to pry.
Fantastic lighting and clear pictures!
Where do I get a replacement key boars
Where did you obtain the parts from as I am having difficulty
