Was du brauchst
Firmly press the cartridge release button with your finger.
You may need to hold the cassette and/or entire device still while pressing the button.
Lift the label tape cassette out of the device.
Use Phillips #00 Screwdriver to disengage cutter from device
Remove cutter
Use Phillips #00 screw to unscrew blade from blade cutter
Replace blade
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
