Einleitung
If you’ve ever watched the series Star Wars, then you’ve heard of its massively successful object, none other than the Lightsaber. There are several different Lightsaber models, and each one requires different techniques to change their batteries successfully. In this guide my team demonstrates how to change the batteries in an Ultrasaber Lightsaber with Sound in only six steps.
Was du brauchst
Unscrew the pommel located at the bottom of the hilt of the lightsaber by turning it to the right.
Grab the hilt and the pommel.
Pull the battery pack out of the lightsaber slowly.
Remove the velcro & electrical tape around the battery pack.
Check to see if the electrical tape around the noise blocker and battery pack can be reused or if it needs to be replaced.
Remove the batteries from the battery pack.
Place your fully charged AAA batteries into the battery pack.
Repeat the battery pack removal process in reverse to secure the battery pack and noise blocker inside your Lightsaber.
If your Dark Apprentice Ultrasaber v5 turns on by pressing the ON button located on the hilt, you have successfully changed the batteries in your Lightsaber.
