Einleitung
Designed as a low cost tablet for students in India, Datawind's Ubislate 7CI sells for about $35, to students in India, with the price subsidized by the government. The device is 7.2 by 4.8 by .4 inches (HWD) and weighs 11.2 ounces.
Was du brauchst
Be sure to repair your device on a clean surface so you are less likely to lose small parts.
Run your prying tool along the front edge of the device to pop off the front cover.
Once the halves are separated your device should look like this.
(HINT: be careful of the device's small wiring when separating the two halves.)
Remove the black tape that is circled.
The camera is circled in this picture.
Slide the new camera into its housing carefully.
it should look like the second picture when you are finished
Press the back cover of the tablet on firmly until it clicks
2 weitere Nutzer:innen haben diese Anleitung absolviert.
