Zum Hauptinhalt wechseln
Datawind Ubislate 7ci Speaker Replacement
Was du brauchst
  1. Datawind Ubislate 7ci Speaker Replacement, Finding a workspace: Schritt 1, Bild 1 von 1
    • Be sure to repair your device on a clean surface so you are less likely to lose small parts.
  2. Datawind Ubislate 7ci Speaker Replacement, Pry open your tablet: Schritt 2, Bild 1 von 2 Datawind Ubislate 7ci Speaker Replacement, Pry open your tablet: Schritt 2, Bild 2 von 2
    • Run your prying tool along the front edge of the device to pop off the front cover.
    • Once the halves are separated, your device should look like this.
    • (HINT: be careful of the device's small wiring when separating the two halves)
  3. Datawind Ubislate 7ci Speaker Replacement, Removing the speaker: Schritt 3, Bild 1 von 1
    • Use your prying tool to pop the speaker out from its housing.
  4. Datawind Ubislate 7ci Speaker Replacement, Detach from contact points: Schritt 4, Bild 1 von 1
    • Use a soldering iron to remove the speaker from its contact points.
  5. Datawind Ubislate 7ci Speaker Replacement, Attaching replacement to contact points: Schritt 5, Bild 1 von 1
    • Solder your new speaker to the same contact points as before.
  6. Datawind Ubislate 7ci Speaker Replacement, Housing the replacement speaker: Schritt 6, Bild 1 von 1
    • Apply a small amount of adhesive to the new speaker, and place it into the housing on the back panel.
  7. Datawind Ubislate 7ci Speaker Replacement, Putting your tablet back together: Schritt 7, Bild 1 von 2 Datawind Ubislate 7ci Speaker Replacement, Putting your tablet back together: Schritt 7, Bild 2 von 2
    • Put the two halves back together.
    • Push down on the edges until you hear them click into place.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Mekides
40 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 6-3, Vijaybhaskar Fall 2014 Mitglied von UMass Dartmouth, Team 6-3, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S6G3
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 276
