Zum Hauptinhalt wechseln
Daymak Max S Kickstand Replacement
Was du brauchst
  1. Daymak Max S Kickstand Replacement, Kickstand Replacing: Schritt 1, Bild 1 von 3 Daymak Max S Kickstand Replacement, Kickstand Replacing: Schritt 1, Bild 2 von 3 Daymak Max S Kickstand Replacement, Kickstand Replacing: Schritt 1, Bild 3 von 3
    • Lower and raise the kickstand several times to check for looseness, bending, or instability
    • Inspect the mounting bolt and bracket to ensure they aren't simply loose.
    Frag FixBot
    Kommentar hinzufügen
  2. Daymak Max S Kickstand Replacement: Schritt 2, Bild 1 von 3 Daymak Max S Kickstand Replacement: Schritt 2, Bild 2 von 3 Daymak Max S Kickstand Replacement: Schritt 2, Bild 3 von 3
    • Carefully flip the bike upside down, resting it on its seat and handlebars.
    • Placing a towel or carpet piece underneath can prevents scratches to components.
    Frag FixBot
  3. Daymak Max S Kickstand Replacement: Schritt 3, Bild 1 von 3 Daymak Max S Kickstand Replacement: Schritt 3, Bild 2 von 3 Daymak Max S Kickstand Replacement: Schritt 3, Bild 3 von 3
    • Remove the 2 bolt securing the kickstand, typically near the rear wheel, using an Allen key or wrench
    Frag FixBot
  4. Daymak Max S Kickstand Replacement: Schritt 4, Bild 1 von 3 Daymak Max S Kickstand Replacement: Schritt 4, Bild 2 von 3 Daymak Max S Kickstand Replacement: Schritt 4, Bild 3 von 3
    • Slide the old, damaged kickstand out of its mounting bracket.
    • If you plan to reuse the original bolt and washer, set them aside in a safe place.
    Frag FixBot
  5. Daymak Max S Kickstand Replacement: Schritt 5, Bild 1 von 3 Daymak Max S Kickstand Replacement: Schritt 5, Bild 2 von 3 Daymak Max S Kickstand Replacement: Schritt 5, Bild 3 von 3
    • Align the new kickstand with the mounting bracket.
    • Insert the bolt through the bracket and kickstand.
    • Tighten the bolt securely using your Allen key (or wrench).
    • Ensure it's snug but be careful not to over-tighten and strip the threads.
    Frag FixBot
  6. Daymak Max S Kickstand Replacement: Schritt 6, Bild 1 von 3 Daymak Max S Kickstand Replacement: Schritt 6, Bild 2 von 3 Daymak Max S Kickstand Replacement: Schritt 6, Bild 3 von 3
    • Carefully return the bike to its upright position.
    • Lower the kickstand on a level surface to verify it supports the bike's weight.
    • Retract the kickstand to ensure it springs back smoothly without hitting the wheel, chain, or frame.
    Frag FixBot
Ziellinie
Eine weitere Person hat diese Anleitung absolviert.
York University, Team M-11, Woodhouse Winter 2026 Mitglied von York University, Team M-11, Woodhouse Winter 2026
YORK-WOODHOUSE-W26SMG11
2 Mitglieder
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 32
Insgesamt: 84
