Einleitung
This piece can be particularly hard to remove. For the last step pliers may be used (and may possibly allow you to replace the press earlier in the guide), but in order to ensure no damage is done using your hands is preferable.
Was du brauchst
Flip open the top panel to reveal water reservoir.
Grab the water reservoir by the handle and lift out.
Flip the device on its head.
Using the Phillips #2 screwdriver, unscrew the four 12 mm screws found at each corner of the bottom panel.
Lift the panel off or flip the device over and let the panel drop out.
Flip the device on its head, front end facing you.
Using the Phillips #2 unscrew the two 52 mm screws found underneath the top portion of the device.
Flip the device back to its proper orientation.
Using the Phillips #2 screwdriver remove the two 52 mm screws found on the lip next to the reservoir.
Insert the two plastic opening tools beneath the top knob.
Use the two plastic opening tools as leverage to lift the top knob off.
Grasp the lid firmly with both hands.
Pull mightily with both hands away from the device.
Use a plastic opening tool to push in the slot on the back panel while lifting.
Similarly, reach into where the reservoir used to be and insert a plastic spudger underneath the inside panel.
You are now ready to lift the top off.
Place one hand near the back, the other at the front, and lift.
Pull out each LED with one quick tug.
Similarly, remove each set of wires from the setting tuner with one quick tug.
Flip the device and remove one end of the tube from the reservoir hole.
Completely remove the other tube from both the reservoir hole and filter to the water pump.
Pull the tube through the chamber with the water pump so it comes out of the top end.
Twist the valve counter-clockwise while pulling gently.
Pinch the two sides of the top of the coffee press to unlatch.
Push down into the device as you pinch.
7 weitere Nutzer:innen haben diese Anleitung absolviert.
