Einleitung
If your heater has a temperature sensor failure alarm proceed with component replacement or repair when possible.
ELECTRONIC BOARD WITH PROBE FOR DE LONGHI FAN HEATER TCH7091ER TCH7092ER
Replacement part available at eBay
Heater unit bricked with PF error (fault temperature sensor)
Remove the four Phillips screws with a Phillips screwdriver
Remove the remaining 2 screws with a Torx screwdriver
Remove the cover
With a soldering iron I proceeded to weld the broken part and to connect the 2 tracks by applying electric wire and some tin.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
100%
Hier starten ›
