Was du brauchst
Remove two 45 mm T20 Torx screws.
Remove one 30 mm T20 Torx screw.
Grab the gear case cover and gently pull it out just enough to where it exposes the lever assembly.
The lever assembly can now be lifted out.
Gently separate the chuck and plastic housing from the hammer drill body.
The removal of the screw from the chuck to separate the plastic housing requires hand strength and specialized tools.
Fast fertig!
Abschluss
