Einleitung
Welcome to the Dewalt Hammer Drill DW511 lever assembly replacement guide. The lever assembly controls whether the drill is in hammer mode or normal drill mode. Over time, the lever assembly can become damaged and need replacement. A damaged lever assembly can become stuck and prevent the drill from running.
Caution should be taken when working with the drill. It needs to be unplugged before working on any part of it.
Was du brauchst
Place an opening tool in the groove line of the handle and pop the back loose.
Grab the drill with two hands and pull the cover off.
Firmly grab the body of the trigger.
Slowly pull the trigger until the entire body is out and only attached by wires.
With sharp point tweezers, push the little metal flap up in the hole holding the wire.
Clamp the wire with blunt tweezers, and slowly pull the wire out.
With a pair of blunt nose tweezers, grab the white wire.
Carefully wiggle the wire loose.
Pull the wire slowly until it comes out.
Use an opening tool to lift up the spring holding down the brush.
Remove the brush from its holding.
With a pair of blunt nose tweezers, grab the red wire.
Remove two 45 mm T20 Torx screws.
Remove one 30 mm T20 Torx screw.
Grab the gear case cover and gently pull it out just enough to where it exposes the lever assembly.
The lever assembly can now be lifted out.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
