Zum Hauptinhalt wechseln
DeWalt D26451 Power Cord Replacement
Was du brauchst
  1. DeWalt D26451 Power Cord Replacement, Power Cord: Schritt 1, Bild 1 von 1
    • Please wear safety glasses while completing this guide.
    • Remove screws (3) from cap by using the T20 torx attachment and unscrewing in a leftward motion.
  2. DeWalt D26451 Power Cord Replacement: Schritt 2, Bild 1 von 1
    • Gently pry the cap off using your fingers or spudger tool.
  3. DeWalt D26451 Power Cord Replacement: Schritt 3, Bild 1 von 1
    • Once cap is off, expose and locate the power cord mounting bracket and remove the 2 screws holding the wire down by using the T15 torx attachment. Once the cord is loose, pull the connectors out
  4. DeWalt D26451 Power Cord Replacement: Schritt 4, Bild 1 von 1
    • Loosen the white and black wire terminals
  5. DeWalt D26451 Power Cord Replacement: Schritt 5, Bild 1 von 1
    • Insert new power cord terminals and tighten down
    • Do not over-tighten
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 14
Insgesamt: 1,315
