Einleitung
The DeWalt D26451 power switch turns the sander on and off. It may not be working because the circuit is out of alignment, there is a tripped breaker, or a stripped wire.
Replacing the power switch may fix your on/off issues. In this guide, we will be teaching you how to replace the switch. You can order a replacement switch here.
Was du brauchst
Remove screws (3) from cap by using the T20 torx attachment and unscrewing in a leftward motion.
Once cap is off, expose and locate the power cord mounting bracket and remove the 2 screws holding the wire down by using the T15 torx attachment. Once the cord is loose, pull the connectors out
Remove screws (3) from the cap using a T20 torx attachment by unscrewing in a leftward motion
Eine weitere Person hat diese Anleitung absolviert.
