Einleitung
This guide will walk you through replacing the plastic arms holding the brushes in place. These are both located at the base of the brush motor and are required for electrical connection.
Was du brauchst
Using the T-15 screwdriver, remove the four 22-mm torx screws holding the back panel in place.
Using the T-6 screwdriver, unscrew torx screw holding the arm in place.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
