Einleitung
This guide will walk you through replacing the brush and spring components of the grinder. These are both located at the base of the brush motor and can be easily replaced.
Was du brauchst
Using the T-15 screwdriver, remove the four 22-mm torx screws holding the back panel in place.
Fast fertig!
Abschluss
