Zum Hauptinhalt wechseln
DeWalt D28110 Power Switch Replacement
Was du brauchst
  1. DeWalt D28110 Power Switch Replacement, Disassembling DeWalt D28110 Gear Case: Schritt 1, Bild 1 von 1
    • Using the T-15 screwdriver, remove the four 22-mm torx screws on the gear case.
    • Unplug the grinder before any disassembly.
  2. DeWalt D28110 Power Switch Replacement: Schritt 2, Bild 1 von 2 DeWalt D28110 Power Switch Replacement: Schritt 2, Bild 2 von 2
    • Pull out the gear case.
  3. DeWalt D28110 Power Switch Replacement, Disassembling DeWalt D28110 Back Panel Disassembly: Schritt 3, Bild 1 von 1
    • Using the T-15 screwdriver, remove the four 22-mm torx screws holding the back panel in place.
  4. DeWalt D28110 Power Switch Replacement: Schritt 4, Bild 1 von 1
    • Use the edge of the spudger to loosen and remove the back panel.
  5. DeWalt D28110 Power Switch Replacement: Schritt 5, Bild 1 von 1
    • Remove the single 20-mm torx screw holding the rear panel in place.
  6. DeWalt D28110 Power Switch Replacement: Schritt 6, Bild 1 von 1
    • Pull back the rear side of the back panel.
  7. DeWalt D28110 Power Switch Replacement, Power Switch: Schritt 7, Bild 1 von 3 DeWalt D28110 Power Switch Replacement, Power Switch: Schritt 7, Bild 2 von 3 DeWalt D28110 Power Switch Replacement, Power Switch: Schritt 7, Bild 3 von 3
    • There is an inner plastic guard behind the motor shaft.
    • Unscrew the four screws at each corner.
    • The guard should pull out with a good firm tug.
  8. DeWalt D28110 Power Switch Replacement: Schritt 8, Bild 1 von 3 DeWalt D28110 Power Switch Replacement: Schritt 8, Bild 2 von 3 DeWalt D28110 Power Switch Replacement: Schritt 8, Bild 3 von 3
    • Just behind the inner guard is the button slide.
    • Use needle nose pliers to pinch and push the button's flanges together, and out of the slot.
  9. DeWalt D28110 Power Switch Replacement: Schritt 9, Bild 1 von 3 DeWalt D28110 Power Switch Replacement: Schritt 9, Bild 2 von 3 DeWalt D28110 Power Switch Replacement: Schritt 9, Bild 3 von 3
    • Using the J-1 screwdriver, unscrew the power cord wires from the red switch box (located in the back of the grinder).
  10. DeWalt D28110 Power Switch Replacement: Schritt 10, Bild 1 von 2 DeWalt D28110 Power Switch Replacement: Schritt 10, Bild 2 von 2
    • Disconnect the motor wires from the other side of the switch box.
    • They wires are connected as a sleeve to the flat pin out of the switch box. A firm pull should do it.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Kean Wee
495 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 18-6, Maness Winter 2015 Mitglied von Cal Poly, Team 18-6, Maness Winter 2015
CPSU-MANESS-W15S18G6
5 Mitglieder
7 Anleitungen geschrieben
Ein Kommentar
Very clear and concise guide with relevent pictures. Very well done, thank you
Michael Creel - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 15
Letzte 30 Tage: 45
Insgesamt: 5,636
