Einleitung
If the battery of your drill is not giving the drill power, a problem you could have is deteriorated battery cells. This guide will show you how to replace the battery cells.
Was du brauchst
Compress the buttons on either side of the battery and lift the drill away from battery.
Remove the six 19 mm, Torx Security 15 screws from the top of the battery.
Remove the old battery cells by slowly pulling them out of the top piece of the battery.
5 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
Where can one get the replacement cells?
