Einleitung
If you realize your battery charger for your drill is not charging, there may be a blown fuse which can be replaced by following this guide.
Was du brauchst
Remove the four 13 mm, Torx Security #15 screws found on the bottom of the charger.
Remove the 19 mm, Torx Security #10 screw found in the charger port.
Then pull the top of the charger off separating it from the bottom.
Once you have located the fuse, if you have the replacement fuse just pull the old one out and put the new one in.
4 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
Can i get some help in locating the fuse in mt dcb 112 dewalt battery charger i cant found it
