Einleitung
If you are having trouble controlling the speed of the drill there may be a problem with your clutch. By following this guide you will learn how to replace it.
Was du brauchst
Compress the buttons on either side of the battery and lift the drill away from battery.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
worthless no info about clutch
