Zum Hauptinhalt wechseln
DeWalt DCF885 Selector Switch Replacement
Was du brauchst
  1. DeWalt DCF885 Selector Switch Replacement, Battery: Schritt 1, Bild 1 von 1
    • Press the battery release button at the top of the battery.
  2. DeWalt DCF885 Selector Switch Replacement: Schritt 2, Bild 1 von 1
    • Pull the battery away from the tool.
  3. DeWalt DCF885 Selector Switch Replacement, Motor Assembly: Schritt 3, Bild 1 von 1
    • Remove the eight 18 mm Torx Security #10 screws.
  4. DeWalt DCF885 Selector Switch Replacement: Schritt 4, Bild 1 von 1
    • Separate the two halves of the outer case. Set the empty side down and out of the way.
  5. DeWalt DCF885 Selector Switch Replacement: Schritt 5, Bild 1 von 1
    • Disconnect the connector from the motor assembly.
  6. DeWalt DCF885 Selector Switch Replacement: Schritt 6, Bild 1 von 1
    • Pull the motor away from the brush assembly.
  7. DeWalt DCF885 Selector Switch Replacement, Brush Assembly: Schritt 7, Bild 1 von 1
    • Lift the brush assembly out of the drill case.
  8. DeWalt DCF885 Selector Switch Replacement: Schritt 8, Bild 1 von 1
    • Pull the armature assembly apart from the brush ring assembly.
  9. DeWalt DCF885 Selector Switch Replacement: Schritt 9, Bild 1 von 1
    • Pry the two circled connectors apart from the brush ring assembly.
  10. DeWalt DCF885 Selector Switch Replacement: Schritt 10, Bild 1 von 1
    • The brush assembly is now removed from the drill body.
  11. DeWalt DCF885 Selector Switch Replacement, Switch Assembly: Schritt 11, Bild 1 von 1
    • Pull the switch assembly up and out of the drill case.
  12. DeWalt DCF885 Selector Switch Replacement, Selector Switch: Schritt 12, Bild 1 von 1
    • Pull the selector switch out from the outer case.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 9
Insgesamt: 703
