Einleitung
This guide will explain the disassembly of the shaft housing and replacement of the shaft.
Was du brauchst
Remove the shoe by pressing the yellow button on the left side of the hand grip.
Remove the four M8x18mm T20 screws on the top of the gearbox.
Pull the top of the gearbox off and set the saw body aside.
Remove the black plastic dust covers using the plastic pry bar.
Remove the two M5 lock nuts using a 5/16" socket.
Turn the housing over and remove the two countersunk M5x17mm T20 bolts from the shaft yoke.
Remove the yoke.
Pull the shaft out of the front of the housing.
Leave the shaft saddle in place over the holes in the cover.
