Einleitung
The DW660 uses a tool-free bit change mechanism, which involves two grips: one locks the motor shaft in place, while the other allows the user to rotate the collet nut independently of the motor shaft.
Press lock button #2 while still holding lock button #1.
Rotate lock button #2 counterclockwise until you see the collet nut become loose.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
