Einleitung
The DeWalt DW660 has an amazing dynamic power switch that makes operating the device extremely easy. The bump off feature of the switch allows for an easy shut off with minimal effort.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Remove the four 19mm T20 Torx screws at the rear of the device.
    • Remove the four 19mm T20 Torx screws at the rear of the device.
  2. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  3. Remove the cover to expose the inside of the tool.
    • Remove the cover to expose the inside of the tool.
  4. Pick up the switch from the device with the wires still attached. Remove the actuator from the switch. Pull the two wires from the switch.
    • Pick up the switch from the device with the wires still attached.
    • Remove the actuator from the switch.
    • Pull the two wires from the switch.
    • Make sure to remember where each pin went on the switch after replacement.
Abschluss
Joseph Pacitto
237 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 2-7, Isaacson Spring 2016 Mitglied von UMass Dartmouth, Team 2-7, Isaacson Spring 2016
UMASSD-ISAACSON-S16S2G7
3 Mitglieder
5 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 188
