Zum Hauptinhalt wechseln
DeWalt DW920 Lock Switch Replacement
Was du brauchst
  1. DeWalt DW920 Lock Switch Replacement, Disassembly: Schritt 1, Bild 1 von 1
    • Using an H-5.0 bit driver remove the four T-10 Torx screws.
  2. DeWalt DW920 Lock Switch Replacement: Schritt 2, Bild 1 von 1
    • Use 2 H-5.0 bit drivers to take out the main bolt and head.
    • There will be blue locktite on the tread.
  3. DeWalt DW920 Lock Switch Replacement: Schritt 3, Bild 1 von 1
    • Carefully remove the two halves of the handle.
  4. DeWalt DW920 Lock Switch Replacement, Lock Switch: Schritt 4, Bild 1 von 1
    • Locate the switch on the top of the drill right before the bending joint.
  5. DeWalt DW920 Lock Switch Replacement: Schritt 5, Bild 1 von 2 DeWalt DW920 Lock Switch Replacement: Schritt 5, Bild 2 von 2
    • Firmly grasp the switch with two fingers and lift it straight up. The spring should remain attached to the switch during this process.
    • It should lift right out. If it is caught on anything do not force it out.
Abschluss
Stephen Rada
433 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team 8-2, Botvin Spring 2016 Mitglied von UMass Dartmouth, Team 8-2, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G2
2 Mitglieder
6 Anleitungen geschrieben
Ein Kommentar
This guide was descriptive and easy to follow. Good job!
DankMemerino - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 281
