Was du brauchst
Gently lift the motor and trigger mechanism out from the frame of the drill.
Locate where the motor assembly is attached to the trigger mechanism and carefully detach the wires at their solder points.
Solder the new motor assembly wires to the trigger mechanism in the same fashion that the old motor was.
Fast fertig!
Abschluss
