Zum Hauptinhalt wechseln
DeWalt DW920 Motor Replacement
Was du brauchst
  1. DeWalt DW920 Motor Replacement, Disassembly: Schritt 1, Bild 1 von 1
    • Using an H-5.0 bit driver remove the four T-10 Torx screws.
  2. DeWalt DW920 Motor Replacement: Schritt 2, Bild 1 von 1
    • Use 2 H-5.0 bit drivers to take out the main bolt and head.
    • There will be blue locktite on the tread.
  3. DeWalt DW920 Motor Replacement: Schritt 3, Bild 1 von 1
    • Carefully remove the two halves of the handle.
  4. DeWalt DW920 Motor Replacement, Motor: Schritt 4, Bild 1 von 1
    • Gently lift the motor and trigger mechanism out from the frame of the drill.
  5. DeWalt DW920 Motor Replacement: Schritt 5, Bild 1 von 1
    • Locate where the motor assembly is attached to the trigger mechanism and carefully detach the wires at their solder points.
    • Mark where the two cables was connected using a masking tape or similar.
  6. DeWalt DW920 Motor Replacement: Schritt 6, Bild 1 von 1
    • Solder the new motor assembly wires to the trigger mechanism in the same fashion that the old motor was.
    • Remember to check the markers from the step before and solder the cables on the right place.
Abschluss
Stephen Rada
433 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team 8-2, Botvin Spring 2016 Mitglied von UMass Dartmouth, Team 8-2, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G2
2 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 13
Insgesamt: 825
