Einleitung
This guide will show you how to replace the black air filter cap located on the top of the motor.
Was du brauchst
Using a T-20 hex head screw, unscrew the two screws located at the top and bottom of the black air filter. The screws are directly above and below the yellow lettering.
Use your hands to pull the black air filter away from the body of the saw to detach.
Eine weitere Person hat diese Anleitung absolviert.
