Einleitung
This guide will show you how to remove the boot of the saw in order to replace it.
Was du brauchst
Use a T-20 hexhead screw to unscrew 4 hexagonal screws surrounding the base of the black air filter. The screws are on the yellow portion.
Use a T-15 hexhead screw to unscrew 5 hexagonal screws. These screws are located on the opposite side of the saw from previous step.
Use a T-15 hex head screw to unscrew the four screws located around the outside of the motor.
Using an H 4.0 hex head screw, unscrew the bolt located right above the boot that is next to the motor of the saw.
Pull the blade away from the body of the saw causing the blade and boot to detach.
