Zum Hauptinhalt wechseln
DeWalt DW936 Plastic Cover Replacement
Was du brauchst
  1. DeWalt DW936 Plastic Cover Replacement, Plastic Cover: Schritt 1, Bild 1 von 1
    • Use a T-20 hexhead screw to unscrew 4 hexagonal screws surrounding the base of the black air filter. The screws are on the yellow portion.
  2. DeWalt DW936 Plastic Cover Replacement: Schritt 2, Bild 1 von 1
    • Use a T-15 hexhead screw to unscrew 5 hexagonal screws. These screws are located on the opposite side of the saw from previous step.
  3. DeWalt DW936 Plastic Cover Replacement: Schritt 3, Bild 1 von 1
    • Remove Allen Key.
  4. DeWalt DW936 Plastic Cover Replacement: Schritt 4, Bild 1 von 1
    • Unscrew the black plastic knob underneath the trigger.
  5. DeWalt DW936 Plastic Cover Replacement: Schritt 5, Bild 1 von 1
    • Grab hold of the black air filter portion and pull off.
  6. DeWalt DW936 Plastic Cover Replacement: Schritt 6, Bild 1 von 1
    • This is what the inside of the saw looks like.
Abschluss
Cal Poly, Team 8-2, Banghart Winter 2017 Mitglied von Cal Poly, Team 8-2, Banghart Winter 2017
CPSU-BANGHART-W17S8G2
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 5
Letzte 30 Tage: 8
Insgesamt: 369
