Einleitung
This guide will show you how to take out the trigger on the saw.
Was du brauchst
Use a T-20 hexhead screw to unscrew 4 hexagonal screws surrounding the base of the black air filter. The screws are on the yellow portion.
Use a T-15 hexhead screw to unscrew 5 hexagonal screws. These screws are located on the opposite side of the saw from previous step.
The trigger has black and white wires coming off of it. Grip the trigger with both hands, one on the plastic trigger part and the other on the plastic by the silver metal piece.
Pull up.
Lift off the silver metal piece using tweezers.
Lift off each hook. (4 corners)
2 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
Then repair trigger by stripping,cleaning,soldering and whatever else before replacing to unit as you can no longer buy the part as it is obsolete!
