Zum Hauptinhalt wechseln
DeWalt DW936 Trigger Replacement
Was du brauchst
  1. DeWalt DW936 Trigger Replacement, Plastic Cover: Schritt 1, Bild 1 von 1
    • Use a T-20 hexhead screw to unscrew 4 hexagonal screws surrounding the base of the black air filter. The screws are on the yellow portion.
  2. DeWalt DW936 Trigger Replacement: Schritt 2, Bild 1 von 1
    • Use a T-15 hexhead screw to unscrew 5 hexagonal screws. These screws are located on the opposite side of the saw from previous step.
  3. DeWalt DW936 Trigger Replacement: Schritt 3, Bild 1 von 1
    • Remove Allen Key.
  4. DeWalt DW936 Trigger Replacement: Schritt 4, Bild 1 von 1
    • Unscrew the black plastic knob underneath the trigger.
  5. DeWalt DW936 Trigger Replacement: Schritt 5, Bild 1 von 1
    • Grab hold of the black air filter portion and pull off.
  6. DeWalt DW936 Trigger Replacement: Schritt 6, Bild 1 von 1
    • This is what the inside of the saw looks like.
  7. DeWalt DW936 Trigger Replacement, Trigger: Schritt 7, Bild 1 von 1
    • The trigger has black and white wires coming off of it. Grip the trigger with both hands, one on the plastic trigger part and the other on the plastic by the silver metal piece.
    • Pull up.
  8. DeWalt DW936 Trigger Replacement: Schritt 8, Bild 1 von 1
    • The trigger should be able to sit freely.
  9. DeWalt DW936 Trigger Replacement: Schritt 9, Bild 1 von 2 DeWalt DW936 Trigger Replacement: Schritt 9, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Lift off the silver metal piece using tweezers.
    • Lift off each hook. (4 corners)
  10. DeWalt DW936 Trigger Replacement: Schritt 10, Bild 1 von 1
    • Pull plastic trigger out of the black plastic casing.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 8-2, Banghart Winter 2017 Mitglied von Cal Poly, Team 8-2, Banghart Winter 2017
CPSU-BANGHART-W17S8G2
3 Mitglieder
5 Anleitungen geschrieben
1 Kommentar zur Anleitung
Then repair trigger by stripping,cleaning,soldering and whatever else before replacing to unit as you can no longer buy the part as it is obsolete!
donald.mcguinnes - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 21
Insgesamt: 984
