Einleitung
If the drill is on but not spinning, then the motor should be replaced.
Was du brauchst
Remove seven 21 mm Torx T15 screws.
Remove one 18 mm Torx T10 screw.
After removing all screws, lift up the top yellow cover.
Lift the components out of the casing. These include: motor, gear assembly, trigger assembly and chuck.
Use a Torx T10 screw bit to remove the four 11mm screws around the motor.
Eine weitere Person hat diese Anleitung absolviert.
