Einleitung
The chuck holds the drill bit in place—and if the chuck becomes broken, the drill serves no function. Use this guide to replace a damaged or broken chuck in the DeWalt DWD112.
Was du brauchst
Remove the top cover to reveal the inside of the drill.
Set the top cover of the drill aside.
Grab the metal chuck by the rotating spindle as if you are to tighten in a drill bit.
Remove the chuck assembly from the drill.
Eine weitere Person hat diese Anleitung absolviert.
Ein Kommentar
Or actually read the manual, and find you can use an allen wrench with no dissasembly at all.
