Einleitung
The power switch is for turning the device on and off. It can have trouble and not work if the button in the switch box wears out. This is a guide on how to repair the power switch
Was du brauchst
Turn to the bottom of the device and remove the 1 1/4" screw shown using a T15 Torx Screwdriver.
Unscrew the pin that is holding the main power cord in place and remove the cord.
Pull back the tab holding the switch box in place using a nylon spudger. There is one on top and bottom shown in the image.
Remove the switch box entirely from its normal position. Gently pull off the connections from the switch box to the motor.
Using a small Phillips head screwdriver, remove the screws that hold the white colored wires from the power cord in place.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
