Zum Hauptinhalt wechseln
DeWalt_D26451 Brake Replacement
Was du brauchst
  1. DeWalt_D26451 Brake Replacement, Pad: Schritt 1, Bild 1 von 3 DeWalt_D26451 Brake Replacement, Pad: Schritt 1, Bild 2 von 3 DeWalt_D26451 Brake Replacement, Pad: Schritt 1, Bild 3 von 3
    • Please wear safety glasses while completing this replacement guide.
    • Insert the 60 mm extension into the screw driver which has the t15 torx bit installed in order to make a t-handle grip.
    • Turn the screwdriver counter-clockwise to loosen all three screws in the disc pad.
  2. DeWalt_D26451 Brake Replacement: Schritt 2, Bild 1 von 2 DeWalt_D26451 Brake Replacement: Schritt 2, Bild 2 von 2
    • Turn the disc pad over and remove the loosened screws.
    • When the screws are removed, the disc pad will come off of the sander.
  3. DeWalt_D26451 Brake Replacement, Brake: Schritt 3, Bild 1 von 1
    • Please wear safety glasses while completing this repair guide.
    • Loosen and remove the three screws on the bottom of the sander that holds the disc pad to the bottom of the sander.
  4. DeWalt_D26451 Brake Replacement: Schritt 4, Bild 1 von 1
    • After the T20 torx bolts have been removed, remove the disc pad from the sander.
  5. DeWalt_D26451 Brake Replacement: Schritt 5, Bild 1 von 1
    • When the disc pad is removed, the brake is located directly under it. Remove the brake from the sander.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 12
Letzte 30 Tage: 31
Insgesamt: 2,245
