Einleitung
The wiring of your motherboard may have been disconnected causing the screen o not function properly. This guide will help you fix that.
Was du brauchst
Remove the (10) P58F black screws on the back cover using the Phillips #0 screwdriver.
After removing the screws, remove the back cover using a plastic or metal spudger.
Unscrew the (6) six black screws outlined using a Phillips #0 screwdriver.
Unscrew (4) screws securing the fan using a Phillips #0 head screwdriver.
Remove the fan from the motherboard.
Unplug all wires from motherboard, including battery wire, speaker wire, screen wire, and other component wires.
Remove the black speaker wire.
Remove the white display wire.
(Continued)Unplug all wires from motherboard, including battery wire, speaker wire, screen wire, and other component wires
Remove the gold and silver display cables.
Remove the white fan cable.
Remove the USB-to-motherboard cable
Remove the black battery cable.
Remove the blue ribbon cable.
Unscrew and remove hard drive/SSD.
Disconnect the hard drive/SSD from the motherboard.
