Einleitung
Use this guide for a SSD in your Dell Adamo 13.
This SSD drive is used to store memory on your computer, and it will speed up how fast your computer works. This storage device is used as a secondary storage device, and will work as primary if other drives are full.
The reason you may be repairing your SSD is because it may be suffering from various issues that lead to problems such as applications freezing or even crashing, frequent blue screen errors or your device won’t even startup.
Before replacing part, be sure to fully power off the device.
Was du brauchst
Remove the bottom cover by unsnapping the clips around the edge of the computer.
Disconnect orange film wire harness from the slot it is connected to.
Remove the battery from the device.
Using the Phillips #0 screwdriver, remove the four 2 mm screws securing the SSD to the motherboard.
