Zum Hauptinhalt wechseln
Dell Adamo 13 Keyboard Replacement
Was du brauchst
  1. Dell Adamo 13 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • There is no external access to the battery. Please make sure the at the battery has been drained or disabled through BIOS before beginning.
    • Flip the device over.
  2. Dell Adamo 13 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Remove the bottom cover by unsnapping the clips around the edge of the computer.
    • You may hear a slight pop when you pull the cover off.
  3. Dell Adamo 13 Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Disconnect orange film wire harness from the slot it is connected to.
    • The bottom cover and battery are one piece and will be replaced as a unit.
    • Remove the battery from the device.
  4. Dell Adamo 13 Keyboard Replacement, Motherboard: Schritt 4, Bild 1 von 1
    • Using the Phillips #0 screwdriver, remove six 2 mm screws securing the fan and motherboard to the device.
  5. Dell Adamo 13 Keyboard Replacement: Schritt 5, Bild 1 von 3 Dell Adamo 13 Keyboard Replacement: Schritt 5, Bild 2 von 3 Dell Adamo 13 Keyboard Replacement: Schritt 5, Bild 3 von 3
    • Remove all the connections to the circuit board on top and underneath.
    • Use caution when removing connections to prevent damage.
    • Remove the motherboard from the device.
  6. Dell Adamo 13 Keyboard Replacement, Keyboard: Schritt 6, Bild 1 von 1
    • Using the Phillips #0 screwdriver, remove eight 2 mm screws securing the keypad to the device.
  7. Dell Adamo 13 Keyboard Replacement: Schritt 7, Bild 1 von 2 Dell Adamo 13 Keyboard Replacement: Schritt 7, Bild 2 von 2
    • Gently lift the keypad out of the laptop mainframe.
Abschluss
Tyler Pourmand
85 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team 3-7, Sinclaire Fall 2021 Mitglied von UMass Dartmouth, Team 3-7, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S3G7
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 145
