Einleitung
We will replace the laptop battery after removing the old battery.
Schritt 1 Removal of the Laptop Battery
Achtung: Die Schritte 1-2 stammen von einer Anleitung, die derzeit bearbeitet wird.
Then turn the laptop around on its back.
On the back of the computer there is a latch that you have to slide and hold in order to remove the battery.
Then you have to push the computer battery towards the computer and rotate upwards.
Finally lift the battery out of the computer.
Align the battery with the battery slot before rotating it in place. There will be a snap.
The battery will already be within the laptop, so no further steps needed.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
