Zum Hauptinhalt wechseln
Dell Adamo XPS Palm Rest Disassembly
Was du brauchst
  1. Achtung: Die Schritte 1-2 stammen von einer Anleitung, die derzeit bearbeitet wird.
    • Turn off the laptop before doing anything to the laptop.
    • Then turn the laptop around on its back.
    • On the back of the computer there is a latch that you have to slide and hold in order to remove the battery.
    • Then you have to push the computer battery towards the computer and rotate upwards.
    • Finally lift the battery out of the computer.
    • Turn the computer around and remove the eighteen screws on the base cover.
    • The screws that secure the base cover are of different sizes. Note the location and size of the screws as you remove them so that you can replace them correctly
    • You aren't actually taking apart the display but only opening it up to gain access to the palm rest panel and keyboard.
    • Use your fingers to ease the palm rest assembly from the computer.
    • Pull on the plastic tab on top of the cables to avoid damaging the connectors.
    • Exercise extreme care while lifting the palm rest assembly to avoid damaging the function key cable.
    • Lift the palm rest assembly to access the function key cable.
    • To prevent damage to the function key cable, do not disconnect the function key cable from the palm rest.
    • Disconnect the function key cable from the connector on the system board.
    • Lift the connector latch that secures the touch pad cable to the touch pad connector and remove the cable.
    • To prevent damage to the display hinges, ensure that you do not adjust the angle between the display and the computer base after removing the palm rest assembly.
    • Lift the palm rest assembly off the computer base.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 10
Insgesamt: 163
